Date/Time: Sat, 23 Nov 2024 17:03:20 +0000
The maln menu item CW
View Count: 235
[2024-08-02 22:02:00] |
User14953 - Posts: 235 |
Can the information that's displayed upon pressing the maln menu item "CW", be displayed in a window similar to that of the Chart Values window?
Date Time Of Last Edit: 2024-08-02 22:06:54
sc cw item.jpg / V - Attached On 2024-08-02 22:06:32 UTC - Size: 6.24 KB - 49 views |
[2024-08-05 13:11:12] |
Refer to the following: Window, CB and CW Menus: Windows and Chartbooks (Window) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-06 02:47:36] |
John, having referenced the documentation you kindly provided, if you could please help me clearly understand then, would that be a yes or a no concerning the question - in regards to the information that's displayed upon pressing the maln menu item "CW", Can that information be displayed in a window similar to that of the Chart Values window? Thanks man.
Date Time Of Last Edit: 2024-08-06 02:51:38
[2024-08-06 14:41:21] |
The only option is the "Windows and Chartbooks" window. Select "Window >> Windows and Chartbooks" to see that window and determine if it gives you what you want.
