Date/Time: Sat, 23 Nov 2024 17:45:53 +0000
Connecting with RJ OBrien
View Count: 176
[2024-08-02 20:15:03]
CatsPajamas - Posts: 4
My futures account is currently with RJ OBrien. They mentioned that they Sierra Chart is available with the CQG API. Can you let me know what data package I need to sign up for connectivity?
[2024-08-02 20:38:07]
What are the exchanges that you are wanting to trade?
In general, we do not have connectivity to CQG for data for the CME Group and EUREX. So you would need to get the data for these exchanges from our Denali Exchange Data Feed. Refer to the information here:
[2024-08-02 21:21:36]
I use CME, CBOT, Eurex. So I understand, you're saying I would get the data through Sierra's Denali feed for those exchanges?
For order routing, would I use the Teton Order Routing? I thought there was (or at least used to be) a CQG routing but that doesn't seem like an option under services now. I just see Denali for data and Teton for routing.
Thanks for the help on a Friday!
[2024-08-02 21:44:31]
This is correct, you would need to use our Denali Exchange Data Feed for your data when connecting with CQG.
We have support for CQG for order routing, just not the data from The CME Group and EUREX. Since you state that you are using "RJ Obrien" and they have support for CQG, you will use CQG for the order routing and use our Denali Exchange Data Feed for the data.
To connect to CQG, you will follow these instructions:
CQG Trading Platform Service: Setup Instructions
To setup the data for the CME Group, follow these instructions:
And to setup the data for EUREX, follow these instructions:
Denali Exchange Data Feed: *Setup Instructions: All Other Exchanges*
