Date/Time: Sat, 23 Nov 2024 18:08:46 +0000
[Programming Help] - Oversized highlighted area on buy and sell column on DOM
View Count: 183
[2024-08-02 12:46:06]
Tr00pz - Posts: 4
First off, love Sierra Chart. Nothing else compares!
As you are already aware, the text and size of certain objects on higher resolution monitors are really small (most importantly, the trade window size). As a result, I've had to increase scaling on windows to 150%. Everything looks great now with some settings changes except for one issue. The highlighted cell on the DOM's buy and sell column covers half of the cell above and below it.
I understand that this is a niche issue as I scoured the boards for other's with the issue to no avail. Is it somehow possible to have a way to change the height of the highlighted area? I can change the cell size to match the highlighted area by showing fewer prices but it doesn't scale at all. If I scale out to show even fewer prices, the highlighted ends up being smaller than the cell. I have screenshots ready at your request.
Thank you for your time.
Tr00pz
[2024-08-02 16:57:49]
Please get us an image of what you are seeing.
[2024-08-02 22:51:11]
Tr00pz - Posts: 4
Thanks for the quick response.
Here's an image when I have as many prices showing as possible.
https://www.sierrachart.com/image.php?Image=1722336725700.png
I can make the highlighted area fit the cell if I show fewer prices.
https://www.sierrachart.com/image.php?Image=1722337257922.png
And this is how it looks if I show even fewer prices.
https://www.sierrachart.com/image.php?Image=1722337278863.png
The highlighted area is not changing size regardless of the cell size. Any thoughts?
Thanks.
Tr00pz
[2024-08-05 13:16:07]
On the "Trade >> Customize Chart/Trade DOM Columns" is an option for each column named "Automatic Sizing". This needs to be enabled for the sizing to adjust based on the data present. Refer to the following:
Global Trade Settings Windows: Automatic Sizing (Trade >> Customize Chart/Trade DOM Columns)
