Date/Time: Sat, 23 Nov 2024 20:08:29 +0000
the file is not compatible
View Count: 141
[2024-08-01 18:41:07] |
User243905 - Posts: 1 |
Hello Could you help me to convert the file to a format which will work with current version of Sierra Chart. File attached. Thank you Wojtek |
[QUANT] PointMap V3.Cht - Attached On 2024-08-01 18:37:15 UTC - Size: 319.25 KB - 150 views Attachment Deleted. |
[2024-08-01 19:41:06] |
Sierra_Chart Engineering - Posts: 17150 |
Refer to the instructions here to do this: Chartbooks (Workspaces): Opening Older Chartbooks Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
