Date/Time: Sat, 23 Nov 2024 19:55:21 +0000
Sierra Chart crashing when not in Safe Mode
View Count: 134
[2024-08-01 16:21:22] |
StephF - Posts: 2 |
Hello my Sierra Chart is crashing when I disable the safe mode. I installed the latest version and uploaded my charts but still crashing. Can you please assist. Can I trade on Safe mode? Can my automated trading system work on Safe mode? Also If I want to trade a Leeloo account, is there any other credentials to indicate apart from the Rithmic ones? Thank you S. |
[2024-08-01 19:52:22] |
Sierra_Chart Engineering - Posts: 17150 |
Refer to this help topic: Sierra Chart Unexpectedly Shutting Down | Memory Errors | Unusual Software Problems | Exception Errors | Freezing of User Interface What is the method in Sierra Chart that you have used to create the automated trading system? Or what particular study? Yes you can perform trading in Safe Mode. Regarding Rithmic, refer to: Technical Support for Rithmic Users is Immediately Discontinued Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-01 19:55:36
