Date/Time: Sat, 23 Nov 2024 19:30:27 +0000
Overlay
View Count: 110
[2024-08-01 15:24:31] |
FCM_CAP - Posts: 2 |
Hello Sierra Team, I wonder how can I have the Volume by price on the front. Because now the number bar is over the VBP (see picture). I tried to move the studies above the VBP but still the same problem. Thank you so much for your time! |
Screenshot 2024-08-01 at 12.07.35 AM.png / V - Attached On 2024-08-01 15:24:06 UTC - Size: 698.63 KB - 41 views |
[2024-08-01 19:39:23] |
Sierra_Chart Engineering - Posts: 17150 |
Put Numbers Bars at the top of the list of studies: Chart Studies: Study Display Order And then uncheck this option for the Volume by Price study: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
