Date/Time: Sat, 23 Nov 2024 17:47:58 +0000
Cumulative Delta Bars and Number Bars Calculated Values
View Count: 173
[2024-08-01 12:53:50]
User19991027 - Posts: 12
Shouldn't the algorithm for cumulative delta bars and number bars calculated values be roughly the same? Why the color ,rise and fall doesn't match, such as the opening time on July 19th
imagebfba5b6071a8c56b9b3a035ea5edf35.jpg / V - Attached On 2024-08-01 12:52:21 UTC - Size: 206.92 KB - 45 views
[2024-08-01 12:56:13]
"Cumulative Sum of Ask Volume & Bid Volume Difference - Day (Day Cumulative AskV - BidV): This is a cumulative bar to bar sum from the beginning of the day based according to the Session Times for the chart, of the difference between the total Ask Volume and the total Bid Volume for each entire Numbers Bar. This is the same as the Cumulative Delta Bars - Volume study."
[2024-08-02 15:40:19]
These will be the same as long as the "Cumulative Delta Bars - Volume" is setup correctly. You would need to have the Inputs for the "Cumulative Delta Bars - Volume" set to the following:
- Perform Rolling Calculation: No
- Reset at Start of Trading Day: Yes
- Reset at Both Session Start Times: No
