Date/Time: Sat, 23 Nov 2024 19:55:12 +0000
Moving Chart / Scale Fix
View Count: 121
[2024-07-31 15:01:26]
User38606 - Posts: 106
Hi, how can I Scale Fix the chart so that I can move the chart up and down. There is this function, Scale Fix in MT4 that when clicked allows you move the chart up and down and it is better visible, and bars can be properly seen. Is there equivalent in Sierra? Because when there is massive move in the price ......chart price action gets tiny and you can't expand chart unless you hide those big bars / scroll the chart to the left. Kinda tiring. Do you have scale fix? Thank u
[2024-07-31 20:26:04]
Sierra_Chart Engineering - Posts: 17150
Refer to:
Chart Scale and Scale Adjusting: Interactive Scaling
