Date/Time: Sat, 23 Nov 2024 19:56:19 +0000
Sub-Instances not streaming live data
View Count: 193
[2024-07-31 14:49:58] |
User547290 - Posts: 58 |
Well.... Typical Sierra Chart I am running several instances of Sierra Chart, yes the current version. Everything is working fine and I save and close the software. Come back this morning for today's FOMC and open SC. And no streaming data on any sub-instance. My main instance works fine, but all sub-instances are receiving live data and will update price if I disconnect and reconnect data from the instance. But will not stream any data to the charts. So what the hell is going on?? I have one instance that will stream NQ and NYSE tic charts but nothing else. |
[2024-07-31 15:55:04] |
Sierra_Chart Engineering - Posts: 17150 |
First refer to help topic 3: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart In the sub instance: Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Close all of the Chartbooks with "File >> Close All Chartbooks". Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only. Disconnect from the data feed with "File >> Disconnect". Connect to the data feed with "File >> Connect to Data Feed". After the connection and after about 10 seconds, provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) We will then determine what the problem is. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-31 15:55:18
[2024-07-31 18:59:56] |
2024-07-31 10:41:10.288 | Trade activity files set size: 601 2024-07-31 10:41:10.398 | Reading Internal Order ID file. 2024-07-31 10:41:10.400 | Reading Trade Orders file. 2024-07-31 10:41:10.401 | Reading Trade Positions file. 2024-07-31 10:41:10.401 | Reading Trade Account Data files. 2024-07-31 10:41:10.407 | UDPListener (1736). Port 22904 | Error binding to UDP port: 22904. Windows error code 10048: Only one usage of each socket address (protocol/network address/port) is normally permitted. 2024-07-31 10:41:10.407 | Software version: 2661 64-bit 2024-07-31 10:41:10.407 | Primary Thread ID: 19100 2024-07-31 10:41:10.407 | Usage end date: 2024-08-11 2024-07-31 10:41:10.407 | Enabled for: Advanced Features 2. 2024-07-31 10:41:10.407 | Enabled for: Sierra Chart Historical Data Service. 2024-07-31 10:41:10.407 | Enabled for: Denali Real-Time Exchange Data Feed. 2024-07-31 10:41:10.407 | Enabled for: Delayed Denali Exchange Data Feed. 2024-07-31 10:41:10.407 | Enabled for exchange2: CME (Trading Account Required) 2024-07-31 10:41:10.407 | Enabled for exchange2: CBOT (Trading Account Required) 2024-07-31 10:41:10.407 | Enabled for exchange2: COMEX (Trading Account Required) 2024-07-31 10:41:10.407 | Enabled for exchange2: NYMEX (Trading Account Required) 2024-07-31 10:41:10.407 | Allow Support for Sierra Chart Data Feeds is enabled. 2024-07-31 10:41:10.407 | Current selected Data/Trading service: DTC - Sub Instance 2024-07-31 10:41:10.407 | Custom symbol settings values: enabled 2024-07-31 10:41:10.407 | Chart Update Interval: 10 2024-07-31 10:41:10.407 | Intraday Data Storage Time Unit: 0 2024-07-31 10:41:10.407 | Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) 2024-07-31 10:41:10.407 | 2024-07-31 14:41:10 Local computer time in UTC 2024-07-31 10:41:10.407 | 2024-07-31 10:41:10 Local computer time in SC Time Zone 2024-07-31 10:41:10.407 | 2024-07-31 14:40:55 Server time in UTC 2024-07-31 10:41:10.407 | Local computer UTC time and Server UTC time difference: 14 seconds. 2024-07-31 10:41:10.407 | Notice: Your computer's clock is off by 14 seconds. Set the 'Global Settings >> NTP Settings >> NTP Client Enable' to 'Yes' or 'Global Settings -> Set System Date-Time from NTP Servers'. 2024-07-31 10:41:10.407 | Program path: C:\Sierra Chart 2-Live\SierraChartInstance_3\ 2024-07-31 10:41:10.407 | Data Files path: C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\ 2024-07-31 10:41:10.407 | OS Version Number: 10.0 2024-07-31 10:41:10.407 | Locale Setting: C 2024-07-31 10:41:10.408 | DLLs: Convergent_64.dll, UserContributedStudies_64.dll 2024-07-31 10:41:10.408 | Allowed protected custom studies: 2024-07-31 10:41:10.408 | Crash reporter started: true 2024-07-31 10:41:10.408 | 2024-07-31 10:41:10.483 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. 2024-07-31 10:41:10.540 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. 2024-07-31 10:41:10.540 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. 2024-07-31 10:41:10.555 | Received 5 login tokens. 2024-07-31 10:41:12.899 | Requested user files to download. 2024-07-31 10:41:14.907 | 2024-07-31 10:41:14.909 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-07-31 10:41:14.930 | DTC Client socket (1) | Creating socket. 2024-07-31 10:41:14.930 | DTC Client socket (1) | New receive buffer size: 0 2024-07-31 10:41:14.930 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-07-31 10:41:14.931 | DTC - Sub Instance | Network connection to server complete. 2024-07-31 10:41:14.931 | DTC - Sub Instance | Starting socket receive thread. 2024-07-31 10:41:14.931 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-07-31 10:41:15.800 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-07-31 10:41:15.800 | DTC - Sub Instance | Sending logon request message. 2024-07-31 10:41:15.973 | DTC - Sub Instance | Received logon response. 2024-07-31 10:41:15.973 | DTC - Sub Instance | Server Name: SC DTC Server. Build=50860M. 2024-07-31 10:41:15.973 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-07-31 10:41:15.973 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2024-07-31 10:41:15.973 | DTC - Sub Instance | Trading is supported. 2024-07-31 10:41:15.973 | DTC - Sub Instance | Order cancel and replace is supported. 2024-07-31 10:41:15.973 | DTC - Sub Instance | OCO Orders supported. 2024-07-31 10:41:15.973 | DTC - Sub Instance | Bracket Orders supported. 2024-07-31 10:41:15.973 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-07-31 10:41:15.973 | DTC - Sub Instance | Connected to server complete. 2024-07-31 10:41:15.974 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-07-31 10:41:15.974 | Subscribing to symbol for symbol alert. ESZ3.CME 2024-07-31 10:41:15.974 | Using symbol data fast lookup vector 2024-07-31 10:41:15.974 | DTC - Sub Instance | Starting real-time market data updates for: ESZ3.CME. ID: 1 Service code: rithmic.trading 2024-07-31 10:41:15.974 | DTC - Sub Instance | Requesting security definition data for: ESZ3.CME. ID: 1 2024-07-31 10:41:15.974 | Subscribing to symbol for symbol alert. ESZ3.CME | Number times message added: 2 2024-07-31 10:41:15.974 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1. 2024-07-31 10:41:16.236 | DTC - Sub Instance | Setting external service identifier for symbol ESZ3.CME to 10 2024-07-31 10:41:16.236 | DTC - Sub Instance | Received security definition for symbol ESZ3.CME 2024-07-31 10:41:17.044 | Symbol settings MD5 received. Request ID: 1. 2024-07-31 10:41:17.044 | Requested symbol settings for service code sc_futures_direct.dtc.trading. Request ID: 2. 2024-07-31 10:41:18.131 | Symbol settings received. Request ID: 2. 2024-07-31 10:41:20.118 | Files to Open on Startup | Opening file: E-1R-Multicharts.Cht 2024-07-31 10:41:20.478 | #3 NQU4.CME [CV] 30 Min | Reloading chart. 2024-07-31 10:41:20.478 | #3 NQU4.CME [CV] 30 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:20.478 | #3 NQU4.CME [CV] 30 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:20.714 | #1 YMU4.CBOT [CV] 60 Min | Reloading chart. 2024-07-31 10:41:20.714 | #1 YMU4.CBOT [CV] 60 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:20.714 | #1 YMU4.CBOT [CV] 60 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:20.931 | #2 ESU4.CME [CB] 60 Min | Reloading chart. 2024-07-31 10:41:20.931 | #2 ESU4.CME [CB] 60 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:20.931 | #2 ESU4.CME [CB] 60 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:20.959 | #4 USDX [CV] 30 Min | Reloading chart. 2024-07-31 10:41:20.959 | #4 USDX [CV] 30 Min | No contract months found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:20.959 | #4 USDX [CV] 30 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:21.166 | #5 NGU4.NYMEX [CV] 60 Min | Reloading chart. 2024-07-31 10:41:21.166 | #5 NGU4.NYMEX [CV] 60 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:21.166 | #5 NGU4.NYMEX [CV] 60 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:21.382 | #6 CLU4.NYMEX [CV] 60 Min | Reloading chart. 2024-07-31 10:41:21.382 | #6 CLU4.NYMEX [CV] 60 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:21.382 | #6 CLU4.NYMEX [CV] 60 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:22.117 | #7 GCZ4.COMEX [CV] 60 Min | Reloading chart. 2024-07-31 10:41:22.117 | #7 GCZ4.COMEX [CV] 60 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:22.117 | #7 GCZ4.COMEX [CV] 60 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:22.360 | #8 SIU4.COMEX [CV] 60 Min | Reloading chart. 2024-07-31 10:41:22.360 | #8 SIU4.COMEX [CV] 60 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:22.360 | #8 SIU4.COMEX [CV] 60 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:22.369 | Files to Open on Startup | Opening file: E-1R - ES.Cht 2024-07-31 10:41:22.728 | #6 ESU4.CME/MESU4.CME [CB] | Reloading chart. 2024-07-31 10:41:22.728 | #6 ESU4.CME/MESU4.CME [CB] | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:22.728 | #6 ESU4.CME/MESU4.CME [CB] | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:22.756 | #8 ESU4.CME [CBV] 1 Min | Reloading chart. 2024-07-31 10:41:22.756 | #8 ESU4.CME [CBV] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:22.756 | #8 ESU4.CME [CBV] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:22.850 | #5 ESU4.CME/MESU4.CME [CB] 15 Min | Reloading chart. 2024-07-31 10:41:22.850 | #5 ESU4.CME/MESU4.CME [CB] 15 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:22.850 | #5 ESU4.CME/MESU4.CME [CB] 15 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:22.889 | #25 ESU4.CME/MESU4.CME [CV] 1 Min | Reloading chart. 2024-07-31 10:41:22.889 | #25 ESU4.CME/MESU4.CME [CV] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:22.889 | #25 ESU4.CME/MESU4.CME [CV] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:23.132 | #34 ESU4.CME [CV] Renko 4t | Reloading chart. 2024-07-31 10:41:23.132 | #34 ESU4.CME [CV] Renko 4t | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:23.132 | #34 ESU4.CME [CV] Renko 4t | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:23.189 | #17 ESU4.CME [CB] 1 Min | Reloading chart. 2024-07-31 10:41:23.189 | #17 ESU4.CME [CB] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:23.189 | #17 ESU4.CME [CB] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:23.230 | #10 ESU4.CME [CBV] 1 Min | Reloading chart. 2024-07-31 10:41:23.230 | #10 ESU4.CME [CBV] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:23.230 | #10 ESU4.CME [CBV] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:23.290 | #11 ESU4.CME [CV] 1 Min | Reloading chart. 2024-07-31 10:41:23.290 | #11 ESU4.CME [CV] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:23.290 | #11 ESU4.CME [CV] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:23.313 | #12 ESU4.CME [CV] 1 Min | Reloading chart. 2024-07-31 10:41:23.313 | #12 ESU4.CME [CV] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:23.313 | #12 ESU4.CME [CV] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:23.874 | #3 ESU4.CME [CV] 15 Min | Reloading chart. 2024-07-31 10:41:23.874 | #3 ESU4.CME [CV] 15 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:23.874 | #3 ESU4.CME [CV] 15 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:24.339 | #7 GCZ4.COMEX [CV-D] 60 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:24.346 | #7 GCZ4.COMEX [CV-D] 60 Min | Chart data loading complete. 2024-07-31 10:41:24.367 | #5 NGU4.NYMEX [CV-D] 60 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:24.377 | #5 NGU4.NYMEX [CV-D] 60 Min | Chart data loading complete. 2024-07-31 10:41:24.634 | DTC - Sub Instance | Starting real-time market data updates for: NQU4.CME. ID: 2 2024-07-31 10:41:24.634 | DTC - Sub Instance | Requesting security definition data for: NQU4.CME. ID: 2 2024-07-31 10:41:24.634 | No historical data client is currently set to download historical Intraday data for NQU4.CME. 2024-07-31 10:41:24.634 | Real-time Intraday chart data file updates started for NQU4.CME 2024-07-31 10:41:24.634 | Intraday chart data file opened for NQU4.CME 2024-07-31 10:41:24.635 | DTC - Sub Instance | Starting real-time market data updates for: YMU4.CBOT. ID: 3 2024-07-31 10:41:24.635 | DTC - Sub Instance | Requesting security definition data for: YMU4.CBOT. ID: 3 2024-07-31 10:41:24.635 | No historical data client is currently set to download historical Intraday data for YMU4.CBOT. 2024-07-31 10:41:24.635 | Real-time Intraday chart data file updates started for YMU4.CBOT 2024-07-31 10:41:24.635 | Intraday chart data file opened for YMU4.CBOT 2024-07-31 10:41:25.040 | DTC - Sub Instance | Starting real-time market data updates for: ESU4.CME. ID: 4 2024-07-31 10:41:25.040 | DTC - Sub Instance | Requesting security definition data for: ESU4.CME. ID: 4 2024-07-31 10:41:25.040 | No historical data client is currently set to download historical Intraday data for ESU4.CME. 2024-07-31 10:41:25.040 | Real-time Intraday chart data file updates started for ESU4.CME 2024-07-31 10:41:25.040 | Intraday chart data file opened for ESU4.CME 2024-07-31 10:41:25.040 | DTC - Sub Instance | Starting real-time market data updates for: USDX. ID: 5 Service code: fxstatscalc 2024-07-31 10:41:25.040 | DTC - Sub Instance | Requesting security definition data for: USDX. ID: 5 2024-07-31 10:41:25.040 | Starting DelayedDownloadMonitoringTimer 2024-07-31 10:41:25.040 | Starting HDTimeoutTimer 2024-07-31 10:41:25.040 | Added historical Intraday data request for USDX to the queue. 2024-07-31 10:41:25.040 | Intraday data recording state for symbol USDX is set to download 'Pending'. 2024-07-31 10:41:25.044 | Triggering next historical data download in queue. 2024-07-31 10:41:25.044 | Delaying start of download for USDX. 2024-07-31 10:41:25.044 | Requesting market depth updates for: ESU4.CME if supported. NumLevels=1400 2024-07-31 10:41:25.044 | DTC - Sub Instance | Starting market orders updates for: ESU4.CME. MinimumMarketByOrderQuantity: 0 2024-07-31 10:41:25.045 | DTC - Sub Instance | Starting real-time market data updates for: NGU4.NYMEX. ID: 6 2024-07-31 10:41:25.045 | DTC - Sub Instance | Requesting security definition data for: NGU4.NYMEX. ID: 6 2024-07-31 10:41:25.045 | No historical data client is currently set to download historical Intraday data for NGU4.NYMEX. 2024-07-31 10:41:25.045 | Real-time Intraday chart data file updates started for NGU4.NYMEX 2024-07-31 10:41:25.045 | Intraday chart data file opened for NGU4.NYMEX 2024-07-31 10:41:25.045 | DTC - Sub Instance | Starting real-time market data updates for: CLU4.NYMEX. ID: 7 2024-07-31 10:41:25.045 | DTC - Sub Instance | Requesting security definition data for: CLU4.NYMEX. ID: 7 2024-07-31 10:41:25.045 | No historical data client is currently set to download historical Intraday data for CLU4.NYMEX. 2024-07-31 10:41:25.045 | Real-time Intraday chart data file updates started for CLU4.NYMEX 2024-07-31 10:41:25.045 | Intraday chart data file opened for CLU4.NYMEX 2024-07-31 10:41:25.046 | DTC - Sub Instance | Starting real-time market data updates for: GCZ4.COMEX. ID: 8 2024-07-31 10:41:25.046 | DTC - Sub Instance | Requesting security definition data for: GCZ4.COMEX. ID: 8 2024-07-31 10:41:25.046 | No historical data client is currently set to download historical Intraday data for GCZ4.COMEX. 2024-07-31 10:41:25.046 | Real-time Intraday chart data file updates started for GCZ4.COMEX 2024-07-31 10:41:25.046 | Intraday chart data file opened for GCZ4.COMEX 2024-07-31 10:41:25.047 | DTC - Sub Instance | Starting real-time market data updates for: SIU4.COMEX. ID: 9 2024-07-31 10:41:25.047 | DTC - Sub Instance | Requesting security definition data for: SIU4.COMEX. ID: 9 2024-07-31 10:41:25.047 | No historical data client is currently set to download historical Intraday data for SIU4.COMEX. 2024-07-31 10:41:25.047 | Real-time Intraday chart data file updates started for SIU4.COMEX 2024-07-31 10:41:25.047 | Intraday chart data file opened for SIU4.COMEX 2024-07-31 10:41:25.050 | DTC - Sub Instance | Starting real-time market data updates for: MESU4.CME. ID: 10 2024-07-31 10:41:25.050 | DTC - Sub Instance | Requesting security definition data for: MESU4.CME. ID: 10 2024-07-31 10:41:25.349 | #8 SIU4.COMEX [CV-D] 60 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:25.359 | #8 SIU4.COMEX [CV-D] 60 Min | Chart data loading complete. 2024-07-31 10:41:25.360 | #6 CLU4.NYMEX [CV-D] 60 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:25.365 | #6 CLU4.NYMEX [CV-D] 60 Min | Chart data loading complete. 2024-07-31 10:41:25.631 | DTC - Sub Instance | Clearing market depth for ESU4.CME 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol NQU4.CME to 20 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol NQU4.CME 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol YMU4.CBOT to 21 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol YMU4.CBOT 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol ESU4.CME to 12 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol ESU4.CME 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol USDX to 1 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol USDX 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol NGU4.NYMEX to 22 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol NGU4.NYMEX 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol CLU4.NYMEX to 23 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol CLU4.NYMEX 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol GCZ4.COMEX to 11 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol GCZ4.COMEX 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol SIU4.COMEX to 24 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol SIU4.COMEX 2024-07-31 10:41:25.632 | DTC - Sub Instance | Setting external service identifier for symbol MESU4.CME to 13 2024-07-31 10:41:25.632 | DTC - Sub Instance | Received security definition for symbol MESU4.CME 2024-07-31 10:41:25.632 | Real-time market depth file updates started for ESU4.CME 2024-07-31 10:41:25.764 | Opened cached Depth file: C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\MarketDepthData\ESU4.CME.2024-07-31.depth 2024-07-31 10:41:25.982 | #12 ESU4.CME [CV-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:26.757 | #11 ESU4.CME [CV-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:26.758 | #1 YMU4.CBOT [CV-D] 60 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:26.857 | #1 YMU4.CBOT [CV-D] 60 Min | Chart data loading complete. 2024-07-31 10:41:27.195 | #3 NQU4.CME [CV-D] 30 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:27.225 | #3 NQU4.CME [CV-D] 30 Min | Chart data loading complete. 2024-07-31 10:41:30.083 | HD Request # 1 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc 2024-07-31 10:41:30.083 | HD Request # 1 | Download start date-time: 2024-07-31 10:20:02.000000. File last date-time: 2024-07-31 10:20:02.000001 2024-07-31 10:41:30.084 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149 2024-07-31 10:41:30.121 | Socket (2) | Creating socket. 2024-07-31 10:41:30.121 | Socket (2) | New receive buffer size: 0 2024-07-31 10:41:30.121 | Socket (2) | Connecting to IP: 69.39.70.241. 2024-07-31 10:41:30.382 | HD Request # 1 | Setting DTC encoding to Binary VLS 2024-07-31 10:41:30.382 | HD Request # 1 | Sending historical data logon request message. 2024-07-31 10:41:30.749 | HD Request # 1 | Requesting Intraday data. Start date-time: 2024-07-31 10:20:02. Record interval: 0. Symbol: USDX 2024-07-31 10:41:30.944 | HD Request # 1 | Decompressing data. 2024-07-31 10:41:31.187 | HD Request # 1 | Receiving Intraday data for USDX starting at 2024-07-31 10:20:02.000000 2024-07-31 10:41:31.188 | Socket (2) | CloseSocket call. 2024-07-31 10:41:31.188 | Historical data download thread signaled to stop. 2024-07-31 10:41:31.188 | HD Request # 1 | Timestamp of first Intraday data file record written: 2024-07-31 10:20:03.000000. 2024-07-31 10:41:31.188 | HD Request # 1 | Received 1282 Intraday data records from 2024-07-31 10:20:02.000000 to 2024-07-31 10:41:23.000000 (21.4 minutes. Delay: 8.2 seconds) and wrote 1281 records for USDX 2024-07-31 10:41:31.189 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2024-07-31 14:41:23.000000 2024-07-31 10:41:31.189 | Added 1 Time and Sales records to Intraday data file for USDX after download. 2024-07-31 10:41:31.190 | HD Request # 1 | Completion time: 1s. 2024-07-31 10:41:31.190 | HD Request # 1 | Intraday data download complete for USDX. Unique request ID: 1 2024-07-31 10:41:31.190 | Removing historical data download ID 1. 2024-07-31 10:41:31.190 | Real-time Intraday chart data file updates started for USDX 2024-07-31 10:41:31.190 | Intraday chart data file opened for USDX 2024-07-31 10:41:31.190 | HD Request # 1 | Enabling Intraday chart updating for symbol. 2024-07-31 10:41:31.190 | 2024-07-31 10:41:31.190 | No download requests in the queue to start downloads for. 2024-07-31 10:41:31.230 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-31 10:41:31.332 | Socket (2) | Socket gracefully closed by remote side. 2024-07-31 10:41:31.332 | Socket (2) | Closed. 2024-07-31 10:41:33.396 | #2 ESU4.CME [CB-D] 60 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:33.399 | #2 ESU4.CME [CB-D] 60 Min | Chart data loading complete. 2024-07-31 10:41:35.145 | #10 ESU4.CME [CBV-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:35.569 | #8 ESU4.CME [CBV-D] 1 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:35.856 | #8 ESU4.CME [CBV-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:36.091 | #8 ESU4.CME [CBV-D] 1 Min | Reloading chart. 2024-07-31 10:41:36.091 | #8 ESU4.CME [CBV-D] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:36.091 | #8 ESU4.CME [CBV-D] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:36.130 | Opened cached Intraday file: C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\USDX.scid. Thread ID: 15896 2024-07-31 10:41:38.713 | Loading market depth data. 2024-07-31 10:41:38.818 | Loaded depth data records for ESU4.CME 2024-07-24 from 2024-07-24 18:00:00.000000 to 2024-07-24 18:31:14.253000. 2024-07-31 10:41:42.411 | #6 ESU4.CME/MESU4.CME [CB-D] | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:42.570 | #6 ESU4.CME/MESU4.CME [CB-D] | Chart data loading complete. 2024-07-31 10:41:43.284 | Loaded depth data records for ESU4.CME 2024-07-25 from 2024-07-24 23:08:39.013000 to 2024-07-25 16:14:19.131000. 2024-07-31 10:41:45.039 | #4 USDX [CV-D] 30 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:46.747 | Loaded depth data records for ESU4.CME 2024-07-26 from 2024-07-26 08:23:52.920000 to 2024-07-26 17:00:00.064000. 2024-07-31 10:41:46.767 | Loaded depth data records for ESU4.CME 2024-07-27 from 2024-07-26 20:53:41.953924 to 2024-07-26 23:31:55.124000. 2024-07-31 10:41:48.762 | #4 USDX [CV-D] 30 Min | Chart data loading complete. 2024-07-31 10:41:49.362 | Loaded depth data records for ESU4.CME 2024-07-29 from 2024-07-29 09:12:25.934000 to 2024-07-29 19:59:59.995000. 2024-07-31 10:41:52.066 | Loaded depth data records for ESU4.CME 2024-07-30 from 2024-07-29 20:00:00.010000 to 2024-07-30 16:34:22.652000. 2024-07-31 10:41:52.202 | Loaded depth data records for ESU4.CME 2024-07-31 from 2024-07-30 20:17:23.932000 to 2024-07-31 09:45:08.399842. 2024-07-31 10:41:52.557 | #8 ESU4.CME [CBV-D] 1 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:52.651 | Chart #8 has tagged chart #6 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:52.666 | #8 ESU4.CME [CBV-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:52.669 | #17 ESU4.CME [CB-D] 1 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:53.350 | Chart #17 has tagged chart #6 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:53.350 | Chart #17 has tagged chart #8 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:53.369 | #17 ESU4.CME [CB-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:53.370 | #34 ESU4.CME [CV-D] Renko 4t | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:53.955 | #34 ESU4.CME [CV-D] Renko 4t | Chart data loading complete. 2024-07-31 10:41:53.956 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:54.322 | Chart #25 has tagged chart #34 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:54.322 | Chart #25 has tagged chart #6 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:54.373 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | Chart data loading complete. 2024-07-31 10:41:55.398 | Chart #17 has tagged chart #25 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:55.398 | Chart #17 has tagged chart #8 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:56.595 | Chart #25 has tagged chart #34 for full recalculation. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:57.056 | #5 ESU4.CME/MESU4.CME [CB-D] 15 Min | Chart data loading complete. 2024-07-31 10:41:57.057 | #3 ESU4.CME [CV-D] 15 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:41:57.452 | #3 ESU4.CME [CV-D] 15 Min | Chart data loading complete. 2024-07-31 10:41:57.703 | #8 ESU4.CME [CBV-D] 1 Min | Performing a full recalculation because it has been tagged. Chartbook: E-1R - ES.Cht 2024-07-31 10:41:57.864 | #5 ESU4.CME/MESU4.CME [CB-D] 15 Min | Reloading chart. 2024-07-31 10:41:57.864 | #5 ESU4.CME/MESU4.CME [CB-D] 15 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:57.864 | #5 ESU4.CME/MESU4.CME [CB-D] 15 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:57.899 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | Reloading chart. 2024-07-31 10:41:57.899 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:57.899 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:41:58.021 | #3 ESU4.CME [CV-D] 15 Min | Reloading chart. 2024-07-31 10:41:58.021 | #3 ESU4.CME [CV-D] 15 Min | Symbol Settings not found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:41:58.021 | #3 ESU4.CME [CV-D] 15 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:42:13.625 | #5 ESU4.CME/MESU4.CME [CB-D] 15 Min | Chart data loading complete. 2024-07-31 10:42:15.633 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:42:15.933 | #25 ESU4.CME/MESU4.CME [CV-D] 1 Min | Chart data loading complete. 2024-07-31 10:42:18.250 | #3 ESU4.CME [CV-D] 15 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:42:18.364 | #3 ESU4.CME [CV-D] 15 Min | Chart data loading complete. 2024-07-31 10:42:18.480 | #34 ESU4.CME [CV-D] Renko 4t | Performing a full recalculation because it has been tagged. Chartbook: E-1R - ES.Cht 2024-07-31 10:42:18.913 | #6 ESU4.CME/MESU4.CME [CB-D] | Performing a full recalculation because it has been tagged. Chartbook: E-1R - ES.Cht 2024-07-31 10:52:45.596 | Added historical Intraday data request for USDX to the queue. 2024-07-31 10:52:45.596 | Intraday data recording state for symbol USDX is set to download 'Pending'. 2024-07-31 10:52:45.596 | Triggering next historical data download in queue. 2024-07-31 10:52:45.596 | HD Request # 2 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc 2024-07-31 10:52:45.596 | HD Request # 2 | Download start date-time: 2024-07-29 20:30:00.000000. File last date-time: 2024-07-31 10:52:38.000000 2024-07-31 10:52:45.596 | HD Request # 2 | Disabling Intraday chart updating for symbol. 2024-07-31 10:52:45.597 | HD Request # 2 | Using server: ds13-2.sierracharts.com port 10150 2024-07-31 10:52:45.597 | Socket (2) | Creating socket. 2024-07-31 10:52:45.597 | Socket (2) | New receive buffer size: 0 2024-07-31 10:52:45.597 | Socket (2) | Connecting to IP: 64.158.105.203. 2024-07-31 10:52:45.691 | HD Request # 2 | Setting DTC encoding to Binary VLS 2024-07-31 10:52:45.691 | HD Request # 2 | Sending historical data logon request message. 2024-07-31 10:52:45.758 | HD Request # 2 | Requesting Intraday data. Start date-time: 2024-07-29 20:30:00. Record interval: 0. Symbol: USDX 2024-07-31 10:52:45.785 | HD Request # 2 | Decompressing data. 2024-07-31 10:52:45.934 | HD Request # 2 | Receiving Intraday data for USDX starting at 2024-07-29 20:30:00.000000 2024-07-31 10:52:45.934 | HD Request # 2 | Truncating file to starting date-time of 2024-07-29 20:30:00.000. 2024-07-31 10:52:46.018 | HD Request # 2 | Timestamp of first Intraday data file record written: 2024-07-29 20:30:00.000000. 2024-07-31 10:52:46.366 | Socket (2) | CloseSocket call. 2024-07-31 10:52:46.366 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-31 10:52:46.383 | Historical data download thread signaled to stop. 2024-07-31 10:52:46.383 | HD Request # 2 | Received 135263 Intraday data records from 2024-07-29 20:30:00.000000 to 2024-07-31 10:52:38.000000 (38.4 hours. Delay: 8.4 seconds) and wrote 135263 records for USDX 2024-07-31 10:52:46.383 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2024-07-31 14:52:38.000000 2024-07-31 10:52:46.383 | Added 2 Time and Sales records to Intraday data file for USDX after download. 2024-07-31 10:52:46.383 | HD Request # 2 | Completion time: 1s. 2024-07-31 10:52:46.383 | HD Request # 2 | Intraday data download complete for USDX. Unique request ID: 2 2024-07-31 10:52:46.383 | Removing historical data download ID 2. 2024-07-31 10:52:46.383 | Real-time Intraday chart data file updates started for USDX 2024-07-31 10:52:46.383 | Intraday chart data file opened for USDX 2024-07-31 10:52:46.383 | HD Request # 2 | Enabling Intraday chart updating for symbol. 2024-07-31 10:52:46.383 | #4 USDX [CV-D] 30 Min | Flagging to reload Intraday data on download completion. 2024-07-31 10:52:46.383 | 2024-07-31 10:52:46.383 | No download requests in the queue to start downloads for. 2024-07-31 10:52:46.399 | Socket (2) | Socket gracefully closed by remote side. 2024-07-31 10:52:46.399 | Socket (2) | Closed. 2024-07-31 10:52:46.414 | #4 USDX [CV-D] 30 Min | Reloading chart. 2024-07-31 10:52:46.414 | #4 USDX [CV-D] 30 Min | No contract months found for symbol. Unable to build continuous futures contract chart. 2024-07-31 10:52:46.414 | #4 USDX [CV-D] 30 Min | There are no continuous futures contract symbols. Loading data normally. 2024-07-31 10:52:50.768 | #4 USDX [CV-D] 30 Min | StartDateTimeForLoadingOrderFills: 2024-07-17 00:00:00 2024-07-31 10:52:51.065 | Opened cached Intraday file: C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\USDX.scid. Thread ID: 15896 2024-07-31 10:52:51.825 | #4 USDX [CV-D] 30 Min | Chart data loading complete. 2024-07-31 10:56:09.924 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0089 seconds. 2024-07-31 10:56:09.941 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0154 seconds. 2024-07-31 11:11:09.950 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0074 seconds. 2024-07-31 11:11:09.965 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0145 seconds. 2024-07-31 11:26:09.973 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0073 seconds. 2024-07-31 11:26:09.990 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0161 seconds. 2024-07-31 11:41:09.989 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0072 seconds. 2024-07-31 11:41:10.005 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0144 seconds. 2024-07-31 11:56:10.007 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0085 seconds. 2024-07-31 11:56:10.021 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0138 seconds. 2024-07-31 12:11:10.038 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0074 seconds. 2024-07-31 12:11:10.053 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0143 seconds. 2024-07-31 12:26:10.080 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0083 seconds. 2024-07-31 12:26:10.095 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0140 seconds. 2024-07-31 12:41:10.101 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0076 seconds. 2024-07-31 12:41:10.115 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0130 seconds. 2024-07-31 12:56:10.114 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0065 seconds. 2024-07-31 12:56:10.129 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0150 seconds. 2024-07-31 13:11:10.129 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0082 seconds. 2024-07-31 13:11:10.142 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0128 seconds. 2024-07-31 13:26:10.153 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0076 seconds. 2024-07-31 13:26:10.168 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0140 seconds. 2024-07-31 13:41:10.176 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0070 seconds. 2024-07-31 13:41:10.189 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0127 seconds. 2024-07-31 13:56:10.187 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0070 seconds. 2024-07-31 13:56:10.204 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0159 seconds. 2024-07-31 14:11:10.204 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0077 seconds. 2024-07-31 14:11:10.220 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0150 seconds. 2024-07-31 14:26:10.227 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0078 seconds. 2024-07-31 14:26:10.241 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0134 seconds. 2024-07-31 14:41:10.249 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0069 seconds. 2024-07-31 14:41:10.263 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0134 seconds. 2024-07-31 14:54:44.996 | Saved Chartbook: E-1R-Multicharts.Cht. Time: 0.0077 seconds. 2024-07-31 14:54:45.010 | Saved Chartbook: E-1R - ES.Cht. Time: 0.0130 seconds. 2024-07-31 14:56:10.286 | #1 ESU24_FUT_CME 1 Min | Reloading chart. 2024-07-31 14:56:10.301 | Source file does not exist when saving backup of C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\Chartbook9.Cht. No backup made. 2024-07-31 14:56:10.301 | Saved Chartbook: Chartbook9.Cht. Time: 0.0002 seconds. 2024-07-31 14:56:10.301 | DTC - Sub Instance | Starting real-time market data updates for: ESU24_FUT_CME. ID: 11 2024-07-31 14:56:10.301 | DTC - Sub Instance | Requesting security definition data for: ESU24_FUT_CME. ID: 11 2024-07-31 14:56:10.301 | Added historical Intraday data request for ESU24_FUT_CME to the queue. 2024-07-31 14:56:10.301 | Intraday data recording state for symbol ESU24_FUT_CME is set to download 'Pending'. 2024-07-31 14:56:10.301 | Triggering next historical data download in queue. 2024-07-31 14:56:10.301 | Delaying start of download for ESU24_FUT_CME. 2024-07-31 14:56:10.306 | DTC - Sub Instance | Setting external service identifier for symbol ESU24_FUT_CME to 118 2024-07-31 14:56:10.306 | DTC - Sub Instance | Received security definition for symbol ESU24_FUT_CME 2024-07-31 14:56:12.980 | #1 ESU24_FUT_CME 1 Min | Chart data loading complete. 2024-07-31 14:56:15.024 | HD Request # 3 | Downloading Intraday chart data for ESU24_FUT_CME to the file ESU24_FUT_CME.scid. Service: cme 2024-07-31 14:56:15.025 | HD Request # 3 | Download start date-time: 2024-07-23 20:30:30.000000. File last date-time: 2024-07-23 20:30:30.593000 2024-07-31 14:56:15.025 | HD Request # 3 | Using server: ds28.sierracharts.com port 10149 2024-07-31 14:56:15.025 | Socket (2) | Creating socket. 2024-07-31 14:56:15.025 | Socket (2) | New receive buffer size: 0 2024-07-31 14:56:15.025 | Socket (2) | Connecting to IP: 67.214.125.5. 2024-07-31 14:56:15.167 | HD Request # 3 | Setting DTC encoding to Binary VLS 2024-07-31 14:56:15.167 | HD Request # 3 | Sending historical data logon request message. 2024-07-31 14:56:15.481 | HD Request # 3 | Requesting Intraday data. Start date-time: 2024-07-23 20:30:30. Record interval: 0. Symbol: ESU24 2024-07-31 14:56:15.538 | HD Request # 3 | Decompressing data. 2024-07-31 14:56:15.610 | HD Request # 3 | Receiving Intraday data for ESU24_FUT_CME starting at 2024-07-23 20:30:30.593000 2024-07-31 14:56:15.797 | HD Request # 3 | Timestamp of first Intraday data file record written: 2024-07-23 20:30:38.408000. 2024-07-31 14:56:27.377 | Socket (2) | CloseSocket call. 2024-07-31 14:56:27.378 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-31 14:56:27.378 | Historical data download thread signaled to stop. 2024-07-31 14:56:27.378 | HD Request # 3 | Received 8553686 Intraday data records from 2024-07-23 20:30:30.593000 to 2024-07-31 14:56:19.357003 (7.8 days. Delay: 8.0 seconds) and wrote 8553685 records for ESU24_FUT_CME 2024-07-31 14:56:27.378 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2024-07-31 18:56:19.357003 2024-07-31 14:56:27.378 | Added 7 Time and Sales records to Intraday data file for ESU24_FUT_CME after download. 2024-07-31 14:56:27.379 | HD Request # 3 | Completion time: 12s. 2024-07-31 14:56:27.379 | HD Request # 3 | Intraday data download complete for ESU24_FUT_CME. Unique request ID: 3 2024-07-31 14:56:27.379 | Removing historical data download ID 3. 2024-07-31 14:56:27.379 | Real-time Intraday chart data file updates started for ESU24_FUT_CME 2024-07-31 14:56:27.379 | Intraday chart data file opened for ESU24_FUT_CME 2024-07-31 14:56:27.379 | HD Request # 3 | Enabling Intraday chart updating for symbol. 2024-07-31 14:56:27.379 | 2024-07-31 14:56:27.379 | No download requests in the queue to start downloads for. 2024-07-31 14:56:27.443 | Socket (2) | Socket gracefully closed by remote side. 2024-07-31 14:56:27.443 | Socket (2) | Closed. 2024-07-31 14:56:31.072 | Opened cached Intraday file: C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\ESU24_FUT_CME.scid. Thread ID: 15896 2024-07-31 14:57:48.953 | File >> Disconnect selected. 2024-07-31 14:57:48.953 | DTC - Sub Instance | Waiting for socket receive thread to end 2024-07-31 14:57:48.954 | DTC Client socket (1) | CloseSocket call. 2024-07-31 14:57:48.954 | DTC Client socket (1) | Shutdown started. Waiting for graceful close. 2024-07-31 14:57:48.954 | DTC - Sub Instance | Disconnected. 2024-07-31 14:57:48.962 | DTC Client socket (1) | Socket gracefully closed by remote side. 2024-07-31 14:57:48.962 | DTC Client socket (1) | Closed. 2024-07-31 14:58:02.099 | 2024-07-31 14:58:02.099 | DTC - Sub Instance | Connecting to the server 127.0.0.1. Port 11099 2024-07-31 14:58:02.099 | DTC Client socket (1) | Creating socket. 2024-07-31 14:58:02.099 | DTC Client socket (1) | New receive buffer size: 0 2024-07-31 14:58:02.099 | DTC Client socket (1) | Connecting to IP: 127.0.0.1. 2024-07-31 14:58:02.099 | DTC - Sub Instance | Network connection to server complete. 2024-07-31 14:58:02.099 | DTC - Sub Instance | Starting socket receive thread. 2024-07-31 14:58:02.099 | DTC - Sub Instance | Sending encoding request to server: Binary VLS. Compression: none 2024-07-31 14:58:02.118 | DTC - Sub Instance | Setting DTC encoding to Binary VLS 2024-07-31 14:58:02.118 | DTC - Sub Instance | Sending logon request message. 2024-07-31 14:58:02.119 | DTC - Sub Instance | Received logon response. 2024-07-31 14:58:02.119 | DTC - Sub Instance | Server Name: SC DTC Server. Build=50860M. 2024-07-31 14:58:02.119 | DTC - Sub Instance | Server protocol version: 8. Client protocol version: 8 2024-07-31 14:58:02.119 | DTC - Sub Instance | Successfully connected. Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading. 2024-07-31 14:58:02.119 | DTC - Sub Instance | Trading is supported. 2024-07-31 14:58:02.119 | DTC - Sub Instance | Order cancel and replace is supported. 2024-07-31 14:58:02.119 | DTC - Sub Instance | OCO Orders supported. 2024-07-31 14:58:02.119 | DTC - Sub Instance | Bracket Orders supported. 2024-07-31 14:58:02.119 | DTC - Sub Instance | MarketDepthIsSupported: 1 2024-07-31 14:58:02.119 | DTC - Sub Instance | Connected to server complete. 2024-07-31 14:58:02.120 | No download requests in the queue to start downloads for. | Number times message added: 3 2024-07-31 14:58:02.120 | Subscribing to symbol for symbol alert. ESZ3.CME 2024-07-31 14:58:02.120 | Using symbol data fast lookup vector 2024-07-31 14:58:02.120 | DTC - Sub Instance | Starting real-time market data updates for: ESZ3.CME. ID: 1 2024-07-31 14:58:02.120 | DTC - Sub Instance | Requesting security definition data for: ESZ3.CME. ID: 1 2024-07-31 14:58:02.120 | Subscribing to symbol for symbol alert. ESZ3.CME | Number times message added: 2 2024-07-31 14:58:02.120 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 3. 2024-07-31 14:58:02.121 | DTC - Sub Instance | Setting external service identifier for symbol ESZ3.CME to 10 2024-07-31 14:58:02.121 | DTC - Sub Instance | Received security definition for symbol ESZ3.CME 2024-07-31 14:58:02.131 | DTC - Sub Instance | Starting real-time market data updates for: ESU24_FUT_CME. ID: 2 2024-07-31 14:58:02.131 | DTC - Sub Instance | Requesting security definition data for: ESU24_FUT_CME. ID: 2 2024-07-31 14:58:02.131 | Added historical Intraday data request for ESU24_FUT_CME to the queue. 2024-07-31 14:58:02.131 | Intraday data recording state for symbol ESU24_FUT_CME is set to download 'Pending'. 2024-07-31 14:58:02.131 | Triggering next historical data download in queue. 2024-07-31 14:58:02.135 | Delaying start of download for ESU24_FUT_CME. 2024-07-31 14:58:02.164 | DTC - Sub Instance | Setting external service identifier for symbol ESU24_FUT_CME to 118 2024-07-31 14:58:02.164 | DTC - Sub Instance | Received security definition for symbol ESU24_FUT_CME 2024-07-31 14:58:03.023 | Symbol settings MD5 received. Request ID: 3. 2024-07-31 14:58:03.023 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading. 2024-07-31 14:58:07.024 | HD Request # 4 | Downloading Intraday chart data for ESU24_FUT_CME to the file ESU24_FUT_CME.scid. Service: cme 2024-07-31 14:58:07.025 | HD Request # 4 | Download start date-time: 2024-07-31 14:57:41.000000. File last date-time: 2024-07-31 14:57:41.366003 2024-07-31 14:58:07.025 | HD Request # 4 | Using server: ds32.sierracharts.com port 10150 2024-07-31 14:58:07.025 | Socket (2) | Creating socket. 2024-07-31 14:58:07.025 | Socket (2) | New receive buffer size: 0 2024-07-31 14:58:07.025 | Socket (2) | Connecting to IP: 67.214.125.3. 2024-07-31 14:58:07.164 | HD Request # 4 | Setting DTC encoding to Binary VLS 2024-07-31 14:58:07.164 | HD Request # 4 | Sending historical data logon request message. 2024-07-31 14:58:07.460 | HD Request # 4 | Requesting Intraday data. Start date-time: 2024-07-31 14:57:41. Record interval: 0. Symbol: ESU24 2024-07-31 14:58:07.520 | HD Request # 4 | Decompressing data. 2024-07-31 14:58:07.588 | HD Request # 4 | Receiving Intraday data for ESU24_FUT_CME starting at 2024-07-31 14:57:41.002000 2024-07-31 14:58:07.589 | Socket (2) | CloseSocket call. 2024-07-31 14:58:07.589 | Socket (2) | Shutdown started. Waiting for graceful close. 2024-07-31 14:58:07.589 | Historical data download thread signaled to stop. 2024-07-31 14:58:07.589 | HD Request # 4 | Timestamp of first Intraday data file record written: 2024-07-31 14:57:41.704000. 2024-07-31 14:58:07.589 | HD Request # 4 | Received 1131 Intraday data records from 2024-07-31 14:57:41.002000 to 2024-07-31 14:57:59.827002 (18.8 seconds. Delay: 7.8 seconds) and wrote 1079 records for ESU24_FUT_CME 2024-07-31 14:58:07.591 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2024-07-31 18:57:59.827002 2024-07-31 14:58:07.591 | Added 16 Time and Sales records to Intraday data file for ESU24_FUT_CME after download. 2024-07-31 14:58:07.591 | HD Request # 4 | Completion time: 0s. 2024-07-31 14:58:07.591 | HD Request # 4 | Intraday data download complete for ESU24_FUT_CME. Unique request ID: 4 2024-07-31 14:58:07.591 | Removing historical data download ID 4. 2024-07-31 14:58:07.591 | Real-time Intraday chart data file updates started for ESU24_FUT_CME 2024-07-31 14:58:07.591 | Intraday chart data file opened for ESU24_FUT_CME 2024-07-31 14:58:07.591 | HD Request # 4 | Enabling Intraday chart updating for symbol. 2024-07-31 14:58:07.591 | 2024-07-31 14:58:07.591 | No download requests in the queue to start downloads for. 2024-07-31 14:58:07.656 | Socket (2) | Socket gracefully closed by remote side. 2024-07-31 14:58:07.656 | Socket (2) | Closed. 2024-07-31 14:58:11.855 | Opened cached Intraday file: C:\Sierra Chart 2-Live\SierraChartInstance_3\Data\ESU24_FUT_CME.scid. Thread ID: 15896 |
[2024-07-31 20:13:39] |
There are a lot of symbols in this log, and most of them are invalid symbols. What is the symbol you are having a problem with? Translate them to the match the current service: Edit Menu: Edit >> Translate Symbols To Current Service Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-31 20:49:52] |
I only had 1 chart of the ES open when I captured this data. I'm having problems with all of them. I have a multi-chart chartbook with the NQ,YM,ES,USDX,NG,CL,GC,SI. All simple charts -- the data comes in and none of the charts will update with live data. I can reload the data and it will load the new data but that's it. I have not changed my chartbooks in months. Then this morning ..... nothing works but the main instance. When I captured the M-Log --> I closed all chartbooks in instance #2 and opened one chart (new 1 min) of the ES and the live data worked. I copied the M Log and sent it to you. It was the only chart open. Then I reloaded my usual chartbook and ...nothing. Now, after market close I re- <translate symbols to current service> for the 5th or 6th time today and live data works. Well, I guess it's working again. Very frustrating, especially on a day like today for SC to not work properly. When I reload ( delete and download data)( from specific time) from charts on instance #2, #3 instance reloads as well.....Is this normal ? I looked at the symbols sent in the M Log and they all look correct to me. Which ones do you see that are invalid? Date Time Of Last Edit: 2024-07-31 20:52:17
[2024-08-01 04:56:50] |
This line indicates you are connecting to Teton order routing: Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading.
Many of the symbols are of the Rithmic format like this: ESU4.CME Symbols formatted like this will not work with Teton order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-08-01 04:57:28
