Date/Time: Sat, 23 Nov 2024 19:34:10 +0000
ES Price multiplied by 100 in Price Axis
View Count: 157
[2024-07-31 03:39:04]
User130696 - Posts: 88
Please see the attached screenshot. Why is the price multiplied by 100? I don't see any settings that can change that. The real-time price multiplier is 1. Also, why would anyone want to multiply the price by hundreds or tens ?
imageScreenshot 2024-07-30 at 11.34.36 PM.png / V - Attached On 2024-07-31 03:36:29 UTC - Size: 404.09 KB - 45 views
[2024-07-31 20:31:38]
Sierra_Chart Engineering - Posts: 17150
You may have change the SC Data Multiplier in the Global Symbol Settings from .01 to 1. That setting needs to be put back to its default setting.
You will need to correct that, and re-download the data:
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
Date Time Of Last Edit: 2024-07-31 20:32:07
