Date/Time: Sat, 23 Nov 2024 19:11:25 +0000
[User Discussion] - How can I save the order/layout of all windows?
View Count: 173
[2024-07-31 02:45:23]
User740504 - Posts: 110
I frequently use two monitors. The tile vertically/horizontally isn't useful because I have different windows of different sizes.
I'm trying to save the order and layout of the windows so when used on another, smaller monitor, I can it re-fit the windows with the click of a button (decrease their size but keep the same relative locations) rather than having windows cut off because there isn't a 1-to-1 match on desktop resolution.
Basically it would figure out what % each window takes up of the screen, and their relative locations, and then resize it to the new monitor's resolution.
Is this possible?
Thanks.
