Date/Time: Sat, 23 Nov 2024 19:58:15 +0000
Can the spreadsheet study draw arrow above the candlestick when specific conditions are me
View Count: 144
[2024-07-31 01:19:18] |
User669552 - Posts: 15 |
Is it possible to draw an arrow above a candlestick if specific conditions are met. Eg when the Highest Ask Volume within a candle is greater than the highest bid Volume. The Max function is not supported in the Simple Alert.
[2024-07-31 20:35:48] |
Sierra_Chart Engineering - Posts: 17150 |
You have to create a custom study to do this: Advanced Custom Study Interface and Language (ACSIL) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
