Date/Time: Sat, 23 Nov 2024 19:42:06 +0000
Block Trade Study
View Count: 209
[2024-07-30 22:39:41] |
Poblano Trading Capital - Posts: 15 |
Hello Sierra Chart team, In other platforms there is indicator called Block Trade, this indicator will have as input the amount of shares you are wanting to see as a block trade, for example if the input is 20,000 shares, the study will show 1 every time it "sees" 1 trade for 20,000 or over, it will show 2 is there was a 2 trades over 20,0000 shares each, etc. Is there any study I can use to identify this block trades? Thank you. |
[2024-07-31 20:36:39] |
Sierra_Chart Engineering - Posts: 17150 |
Have a look at this study: Large Volume Trade Indicator Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
