Date/Time: Sat, 23 Nov 2024 19:08:30 +0000
How to stop using Rithmic
View Count: 135
[2024-07-30 19:46:41] |
User246159 - Posts: 1 |
Hi, I don't need to use Rithmic anymore and I see the message log constantly login in and out and I don't know how to stop that. Thanks!
[2024-07-31 13:39:30] |
Sierra_Chart Engineering - Posts: 17150 |
To access historical and streaming market data independent from your Trading service. Follow these instructions. Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
