Date/Time: Sat, 23 Nov 2024 19:55:12 +0000
Spreadsheet : Periodically Save Sheet as Text in Minutes not sending calculated values
View Count: 211
[2024-07-30 19:34:29] |
User193408 - Posts: 41 |
hello, when using the "Periodically Save Sheet as Text in Minutes" function of the spreadsheet study, i have the following problem : spreadsheet have standard data columns A->G columns => all ok i have data in the TSV file spreadsheet have extra calculations on columns AA => the TSV file will show me the formula contained in the cell instead of the result of the calculation is this normal ? is there a way to export the calculated values in the TSV file ? thank you |
[2024-07-30 20:17:21] |
Please update to the latest release. There was a recent release that fixed this. Follow these instructions to update: Software Download: Fast Update For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-30 20:38:12] |
thank you John - i've just updated to the latest release and i still have the same issue (please see attached)
Date Time Of Last Edit: 2024-07-30 20:56:43
spreadsheet.JPG / V - Attached On 2024-07-30 20:37:14 UTC - Size: 142.02 KB - 45 views |
[2024-07-31 16:01:41] |
please any update as i really need to use this functionality properly
[2024-07-31 23:23:22] |
Sierra_Chart Engineering - Posts: 17150 |
We need some time to look this over.
[2024-08-01 12:33:23] |
thank you - i hope to hear from you soon.
