Date/Time: Sat, 23 Nov 2024 18:56:57 +0000
Pulling/Stacking only showing 2 digits deep for ES
View Count: 246
[2024-07-30 13:03:57] |
User271659 - Posts: 13 |
Hello Support, When I switch to rithmic from my personal account CQG, or from the trading evaluator, the pulling and stacking for ES on rithmic only populates to 2 digits. I can't figure out why? I have the Denali feed. Thanks, |
[2024-07-30 15:02:00] |
Please give us an image of what you are seeing by following these instructions: Support Board Posting Information: Attaching or Posting a Screenshot/Image (Optional) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-30 19:40:38] |
Hi John, here is the image requested. https://www.sierrachart.com/image.php?Image=1722368300520.png Thanks, |
[2024-07-30 20:28:24] |
That is the Sum of the Pulling/Stacking columns. So these kind of numbers are not unusual for this, particularly during standard trading. You can control the number of levels of Pulling/Stacking, which can have an effect on this. Refer to the following: Global Trade Settings Windows: Maximum Bid/Ask Market Depth Pulling/Stacking Levels (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Also refer to the following settings that can also affect the Pulling/Stacking numbers, and hence the totals: Global Trade Settings Windows: Limit Maximum Pulling Stacking Value to Current Depth Quantity (Global Settings >> Chart DOM Settings >> Other >> Other Settings) Global Trade Settings Windows: Add Trade Volume to Pulling Stacking Value For Price (Global Settings >> Chart DOM Settings >> Other >> Other Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-30 22:45:04] |
Hi John Here is a side-by-side comparison of what I am trying to explain. Same time but rhythmic on the left shows no depth. |
Attachment Deleted. Screenshot 2024-07-30 183957.png / V - Attached On 2024-07-30 22:45:00 UTC - Size: 239.33 KB - 54 views |
[2024-07-31 16:13:27] |
Good Afternoon, John, here is another screen shot of today's pulling and stacking on the ES. As soon as change to my personal account or trading evaluator i am get the full depth. https://www.sierrachart.com/image.php?Image=1722442231668.png Thanks for helping with this. |
[2024-07-31 20:15:23] |
Sierra_Chart Engineering - Posts: 17150 |
Set that chart to display market depth data, and also pulling and stacking data: Trade Menu: Show Market Data Columns (Trade menu) And: Global Trade Settings Windows: Customize Chart/Trade DOM Columns (Chart Specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-07-31 20:16:30
