Date/Time: Sat, 23 Nov 2024 18:38:16 +0000
auto lock trading
View Count: 144
[2024-07-30 11:16:02] |
User531621 - Posts: 91 |
Hello! Do you have tool to lock trading for 24 hours if you lose X amount in a session? Thank you |
[2024-07-30 15:01:17] |
Since you are using Rithmic, the only thing we have available is the following: Global Profit/Loss Management There is a Server Profit/Loss Management tool with the "Simulated Futures Trading Service", so if you happen to be using that, then refer to the following: Server Based Profit/Loss Management For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
