Date/Time: Sat, 23 Nov 2024 18:57:26 +0000
Incorrect TPO after symbol rollover
View Count: 135
[2024-07-30 07:55:31] |
User538826 - Posts: 7 |
I am having trouble with my tpo chart when i had carried a symbol rollover on gold futures today. I have attached the screenshot of what I mean. On the candle stick is shows price opening today near yesterdays close. however on my tpo chart today tpo has jumped drastically higher from yesterdays close and does not reflect the same price movement as the candlestick. I am not sure to why this is happening a is have two daily tpos and on one of them it is showing the correct movement (green markings). i am not sure why this is happening?.
error candlestick.png / V - Attached On 2024-07-30 07:55:07 UTC - Size: 112.74 KB - 36 views |
[2024-07-30 14:53:36] |
One of your charts is set to a "Continuous Futures Contract - Volume Based Rollover" and the other is set to "Continuous Futures Contract - Date Based Rollover". This means that the rollover will occur at different dates for those two charts. In particular, we see that the Date Based Rollover occurs on July 30, 2024, but the Volume Based Rollover occurs on July 28, 2024. Refer to the following regarding the rollover options: Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
