Date/Time: Sat, 23 Nov 2024 19:33:18 +0000
Overlay Bar Separation
View Count: 127
[2024-07-29 18:28:54]
User754716 - Posts: 11
I tried everywhere to look for the answer but have not found it. I am including image. I set the overlay bar thickness to 4 spaces but still is overlapping numbers.
https://www.sierrachart.com/image.php?Image=1722027552934.png
[2024-07-29 19:13:35]
You need to set the width of the Candlestick to be very narrow. To do this, open the "Chart >> Graphics Settings - Chart" and deselect the option at the top that states "Use Global Graphics Settings Instead of These Settings". Then select the "Other" tab and set the "Candlestick Width" to a value around "10".
You may have to re-apply the Study/Price Overlay study after making this change.
