Date/Time: Sat, 23 Nov 2024 19:43:04 +0000
Same Chart but looks different
View Count: 201
[2024-07-29 12:57:28]
User131975 - Posts: 78
Hello, unfortunately I currently have the problem that the data is somehow displayed differently in Sierrachart.
At Tradingview and Quantower I have e.g. gaps in the daily chart (which is correct) and partly different lows and highs.
But with Siuerrachart it all looks as if the data has been adjusted, which is not good because I am basically trading a different chart.
Is there a solution for this?
Date Time Of Last Edit: 2024-07-29 12:57:36
imageScreenshot 2024-07-29 145659.png / V - Attached On 2024-07-29 12:57:10 UTC - Size: 32.63 KB - 46 views
imageScreenshot 2024-07-29 145643.png / V - Attached On 2024-07-29 12:57:16 UTC - Size: 87.23 KB - 48 views
[2024-07-29 13:51:04]
Sierra_Chart Engineering - Posts: 17150
You may want to use a Continuous Futures Contract chart:
Continuous Futures Contract Charts
[2024-07-29 13:58:13]
Ah yes Thank you so much!
I think thats the right one i need or ?
imageScreenshot 2024-07-29 155710.png / V - Attached On 2024-07-29 13:58:06 UTC - Size: 4.28 KB - 50 views
[2024-07-29 14:25:03]
Yes that is what we would recommend.
