Date/Time: Sat, 23 Nov 2024 18:46:31 +0000
Trading Activity Log - Export Trades Tab + Currency Value not working
View Count: 158
[2024-07-29 09:11:39] |
User513390 - Posts: 49 |
Dear Support, I have already read the Support Board and read the Support Documentation and no answer How can i export the Trades Tab to an excel format? Also the Currency Value is not showing up as you can see in the photos attached. Sierra version 50081 I need those above to export to my own trading excel log, for your information, i know how to use excel well. I'm available to have remote access assistance Now i need professional advise to solve my problems. Looking forward to hear from you, Rod |
20240729_101919.jpg / V - Attached On 2024-07-29 09:00:43 UTC - Size: 2.82 MB - 38 views |
[2024-07-29 17:15:51] |
We first want you to update Sierra Chart. This is extremely important. Instructions: Software Download: Fast Update Simply select the Trades tab and then save the log following these instructions: Trade Activity Log: File >> Save Log As Do not use export. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-31 08:39:54] |
Dear Support, There is a bug on Trading activity log, display setting. Can't chose anything, it creates a new window to choose but get stuck on currency value |
[2024-07-31 20:08:11] |
Sierra_Chart Engineering - Posts: 17150 |
We just tested now the Trade Activity Log and do not see any issue. Are you running Sierra Chart, under another operating system other than Windows? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
