Date/Time: Sat, 23 Nov 2024 19:24:57 +0000
TICK-NYSE more than 30 days of history
View Count: 165
[2024-07-27 07:51:14] |
ppoignot - Posts: 10 |
Hello, I can't get more than 30 days of history on the "TICK-NYZE" symbol. However, I have the same configuration as on my other charts. Is there a particular configuration? Thanks for your help, |
Capture d'écran 2024-07-27 094956.png / V - Attached On 2024-07-27 07:50:28 UTC - Size: 7.11 KB - 45 views Attachment Deleted. |
[2024-07-28 00:11:21] |
Sierra_Chart Engineering - Posts: 17150 |
Refer to: Historical Intraday Data (Missing Data / Download Errors / Viewing More Data): Downloading/Viewing More Historical Intraday Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
