Date/Time: Sat, 23 Nov 2024 19:31:47 +0000
[User Discussion] - Vbp, how can I change diagonal ask volume - bid volume text color
View Count: 207
[2024-07-27 05:26:25] |
Flowdity - Posts: 46 |
Dear Support In Vbp setting, when I use Ask volume - bid volume in Display volume in bars, I can set different text color from subgraph --> volume numbers text color and size but when I want to use diagonal ask volume - bid volume, I dont find an option to use different text color for +/- numbers Could you advise please? Date Time Of Last Edit: 2024-07-27 06:24:01
[2024-07-29 14:39:14] |
There is not a way to color the Diagonal Difference volumes different colors based on +/-. This is due to the system coloring the full line of the numbers and there is not a separation for the two numbers that are displayed in this case.
