Date/Time: Sat, 23 Nov 2024 19:55:00 +0000
Possible to overlay zig-zag line onto lower timeframe chart?
View Count: 161
[2024-07-26 20:12:44] |
User68474 - Posts: 201 |
Is it possible to overlay the actual zig-zag line (usually ID#.SG1) from a longer timeframe chart onto a lower timeframe chart with same symbol? Example: ZZ line from a 15 min. chart onto a 5 min. chart, etc.?? If so, also possible "vice versa"??
[2024-07-26 20:35:19] |
Yes, you can do the overlay, but when going from a lower time frame to a higher one, you will lose any "turns" that occurred within the time frame of the higher time frame bars. In other words, if you were overlaying from a 5 minute to a 15 minute chart, any "turn" that occurred in a time period of less than 15 minutes will not show on the 15 minute chart. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-07-26 23:37:37] |
Thanks, John. Got it on, but having to play around with the Inputs of both Source chart and Destination chart to make a straight, zig-zag line. I think I got it.
