Date/Time: Sat, 23 Nov 2024 19:22:46 +0000
Linking Studies
View Count: 134
[2024-07-26 08:03:19]
nicktrader - Posts: 709
In ‘Linking’ there is also the option of linking studies. To set a YES here, it only makes sense if the same number and the same studies are integrated in each linked TF. For example, if I have 10 studies in M15 and 15 studies in M3, the linking does not help... (my understanding)
Is there perhaps a possibility that I do not link at ‘chart level’, but at ‘study level’? (Hope, you understand my intention)
I use a large part of same studies in all TFs. If I have to change one or more studies in one TF, I also have to adapt them in the other TFs. It would be easier for me (e.g.) if I could say that this study is linked to the same study in other TFs (you can tick the boxes for the ‘Include in...’ options. Perhaps additionally for the linking of the study).
Is there a way?
Many thanks
[2024-07-26 17:37:43]
You are correct, the linking option will add/remove studies in all linked charts as they are added/removed in another chart.
There really is nothing that can be done for this - you would have to update the individual studies.
