Date/Time: Sat, 23 Nov 2024 21:55:13 +0000
I cant see properly my screen
View Count: 120
[2024-07-18 16:13:33] |
User518457 - Posts: 3 |
Hello i need some help,how i fix my sierra chart to see it properly? i have one layout but i cant see normal even when i move it i see only some parts of the chart how i fix that?
Screenshot (4).png / V - Attached On 2024-07-18 16:04:26 UTC - Size: 158.68 KB - 41 views Attachment Deleted. |
[2024-07-18 16:39:43] |
Set your scaling to "Automatic" and reset your scales. Refer to the following: Chart Scale and Scale Adjusting: Automatic (Scale Range) Chart Scale and Scale Adjusting: Resetting the Scale For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
