Date/Time: Sat, 23 Nov 2024 22:51:15 +0000
Draw a line at US opening price in a 60min chart
View Count: 114
[2024-07-16 15:28:16] |
User251043 - Posts: 46 |
Hi, I'd like to see the US open price in a 60min chart. My timezone is ECT. When using a 60min chart and the Horizontal Line at Time study I see the open of the 60min bar, but not the open of the US session. I don't want to use a 30min chart, but the 60min chart. What study & config can I use to have a line at the exact opening price at 15:30? Thank you. |
[2024-07-16 17:40:19] |
If you do not have a bar that starts at 15:30, then you will not be able to get the Open for that time. If you do not want to change your current chart to get this, then you would need to open another chart that does have the bars set in a way that you can get that value and then you can use the "Study/Price Overlay" to get that value to the chart you want. Refer to the following: Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
