Date/Time: Sat, 23 Nov 2024 22:38:12 +0000
slope of the regression line tool
View Count: 142
[2024-07-16 13:43:03] |
User140473 - Posts: 5 |
I hope you are doing well. I am currently using the linear regression tool and I am wondering if there is a way to get the slope of the regression line Best regards BB |
[2024-07-16 17:18:01] |
There is not a built-in way to get the slope of the Linear Regression Tool. You could create a custom study to do this. Refer to the following: Using Drawing Tools From an Advanced Custom Study: sc.GetUserDrawnChartDrawing() List of Third Party Sierra Chart Study and System Programmers There is also a study named "Linear Regression Slope", which would give you the slope of a linear regression line of a certain length at a particular point. Refer to the following: Linear Regressive Slope For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
