Date/Time: Sat, 23 Nov 2024 23:22:07 +0000
MULTIPLE CHARTS
View Count: 124
[2024-07-10 19:19:59]
paolopens - Posts: 18
CAN YOU HELP HOW TO SET UP SHORTCUT KEYS FROM 1 CHART TO NEXT CHART? IF I HAVE 4 CHARTS. I CAN JUST USE HOTKEY FROM 1-4. THANKS
[2024-07-10 19:23:38]
There are built-in options for "Next Chart" and "Previous Chart". These are under the "Window" menu and they use F9 and F4 keys respectively.
There is also an option for "Window >> Goto Chart Number", which will prompt you for which chart number to change to.
