Date/Time: Sat, 23 Nov 2024 23:46:42 +0000
Number Bars Background Color does not show
View Count: 130
[2024-07-10 15:47:21]
User471548 - Posts: 27
I have set the following:
Column 1 Background Type - Full Background
Column 1 Background Coloring Method - Based on Diagonal Dominant Side AskVol BidVol Percentage.
Column 1 Percent Compare Thresholds - 1.25,1.5,2.0
However, the background colors on my number bars do not show. I tried changing the Compare Thresholds to various different values, but the background colors still do not show. Please help.
I have attached the number bars I am seeing for your reference.
imageScreenshot 2024-07-10 233517.png / V - Attached On 2024-07-10 15:46:02 UTC - Size: 2.11 KB - 38 views
[2024-07-10 16:58:44]
What are your "Column # Range # Up/Down Colors" set to?
[2024-07-11 03:01:36]
My Column 1 Range 0 Up and Down colors are both set to white.
My Column 1 Range 1-3 Up colors are set to blue with increasing intensity (from light blue to dark blue).
My Column 1 Range 1-3 Down colors are set to red with increasing intensity (from light red to dark red).
My default background color is set to white.
[2024-07-11 03:58:10]
I found the error. I have set the Bid/Ask Minimum Volume Compare Threshold to 1800. As a result, no matter how I changed the Compare Thresholds, the background colors would not show.
Sorry to trouble you. Thanks.
