Date/Time: Sat, 23 Nov 2024 12:18:08 +0000
[feature request] multiple select time alert
View Count: 223
[2024-06-18 14:37:13] |
cesium - Posts: 85 |
sometimes, seemingly randomly, but sparingly, repeating time alerts dont trigger, then they get behind, and i have to update all of them for the upcoming day can we get a feature to multiple select alerts to edit so i can plug in a new triggering date and apply to all selected? i have not located a cause for the alert falling behind, i dont think it has something to do with mute all alert being on for extended periods right? thank you John/Engineering Team |
[2024-06-18 15:05:13] |
We can not say when we would get to any particular feature request. But we are a bit concerned about your statement that the alerts are not working as you are expecting. Are the Time Alerts showing as having occurred in the Alert Manager log? If so, then is it just that you are not getting the sounds from the alerts? If your alerts are very close in time, then you may want to set the following option to "Yes": General Settings Window: Wait for Prior Alert Sound to Finish Before Playing Next Queued Sound (Global Settings >> General Settings >> Alerts >> Additional Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-08-25 23:18:39] |
Support not needed, just to follow up with the request, the issue would occur when sc would crash, which was caused by a bug on my end, not sc. Thank you John
Date Time Of Last Edit: 2024-08-25 23:19:35
