Date/Time: Sat, 23 Nov 2024 17:04:35 +0000
One study will overlay one will not
View Count: 174
[2024-06-08 18:34:59] |
User936941 - Posts: 23 |
Hello, I have a weird problem that I cannot figure out. I am making a really simple chartbook and I cannot get one study (FVG) from a 60 minute source chart to overlay onto a 5 minute destination chart, but I can get another study (zigzag) from the same source to display on the same destination. I have gone through all of the settings and can't seem to figure it out. I have also read the documentation for the study/price overlay including the trouble shooting suggestions for this issue on the bottom of that page. I have provided the chartbook file below. Any help is much appreciated. |
[2024-08-06 17:14:28] |
User754716 - Posts: 11 |
My Number bars overlay chart study is gone all of a sudden while changing some settings. I opened backup but no luck. It is on the study list under Studies.
[2024-08-06 18:22:27] |
We can not help you with the FVG study (we assume this is Fair Value Gap). This is not one of our studies, so we do not know anything about it. With regards to the Numbers Bars overlay, you can not overlay a Numbers Bars study. Are you referring to a Numbers Bars Calculated Values study? If so, you can only use the overlay option within the Numbers Bars Calculated Values study for this. Refer to the following: Numbers Bars: Overlaying a Numbers Bars Calculated Values Study from Another Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
