Date/Time: Sat, 23 Nov 2024 09:05:09 +0000
Max Bid/Ask Pulling/Stacking Levels as Chart setting not global
View Count: 330
[2024-01-18 19:22:35]
User311344 - Posts: 139
Hey,
Any chance to make Max Bid/Ask Pulling/Stacking Levels as Chart setting not global setting?
I imagine it's being computed on feed level for every SC instance, but would it be so hard or cpu consuming to make those calculations according to chart setting?
Any chance for ETA or definitely no plans for that?
Date Time Of Last Edit: 2024-01-18 19:23:08
[2024-03-12 11:18:52]
Wernitschanton - Posts: 24
+1 It would be great, if you could set the pulling/stacking depth independently for different products!
[2024-07-31 00:16:50]
TriStar Trading - Posts: 142
FWIW - I use separate sub-instances for each of my products
[2024-09-02 14:59:28]
User2069 - Posts: 20
+1 This would be a huge QOL for those that have multiple DOMs on the same CB. Some symbols need a lot more levels, specially when combining ticks. This leaves a pretty excessive amount on less volatile products far exceeding the average range when it can only be applied globally. I'm sure you guys working on more pressing features but this would be great to have if possible
