Date/Time: Sat, 23 Nov 2024 15:44:27 +0000
Can Denali feed be used with a DTC trading server?
View Count: 331
[2023-11-04 19:53:25] |
glacialspring - Posts: 26 |
I'm exploring writing a DTC server to interface with the new TastyTrade API and would ideally like to use Denali market data. Is it possible?
[2023-11-05 19:15:54] |
Sierra_Chart Engineering - Posts: 17150 |
Yes it is possible through adjusting the Symbol Settings. You would need to add custom Symbol Settings for the symbols.
[2024-11-18 16:21:48] |
User223231 - Posts: 15 |
@glacialspring did you succeed with this? I am trying to do the same (Denali Data with a custom DTC server for trading with Schwab). Could you elaborate on what setup you used on the SC side? Thanks.
[2024-11-18 17:34:25] |
You can use the DTC server to get trade events, so it would be possible to trade on Schwab using those. Market data is no longer available through the DTC server due to regulations so you'll have to do any processing within Sierra Chart.
[2024-11-18 17:50:55] |
Thanks. I guess my questions is, when I set the Data/Trade Service setting to connect to my DTC server for trading functionality, how do I still get the Denali realtime data for my chart? The trade service and data service seem to be a single setting instead of seperate.
[2024-11-19 15:45:35] |
Not sure this is going to work, but these are the relevant Symbol Settings: <sc-data-symbol>ES?##</sc-data-symbol>
<sc-data-symbol-multiplier>0.01</sc-data-symbol-multiplier> <sc-data-srvcode>cme</sc-data-srvcode> <realtime-data-client>SC_Exchange_Data_Service_Sub_Client_4</realtime-data-client> But this may not work trying to change those. Although it should work if you have your own custom symbol. So you have to create your own custom Symbol Settings for the symbol that you are using in the instance of Sierra Chart connected to your DTC server. And modify the above settings appropriately. Refer to: Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-11-19 15:46:17
