Date/Time: Sat, 23 Nov 2024 15:00:04 +0000
ACSIL - access order allocation?
View Count: 365
[2023-09-16 01:24:54]
User370774 - Posts: 25
Good day!
A while ago on a certain release Sierra Chart stopped saving the state of "order allocation" with the chartbook.
Since then it has to be enabled each time Sierra restarts. I'm sure that is to safe people from forgetting that it is enabled.
My question is, is there a way to access "enable order allocation via ACSIL?
If it can't be changed via ACSIL maybe there is a way to check the status so I can write something that gives me some annoying color if it is off?
Thank you in advance!
Best,
WELD
[2023-09-19 17:29:54]
Sierra_Chart Engineering - Posts: 17145
Update Sierra Chart and refer to this new setting:
Global Trade Settings Windows: Disable Order Allocation To Trade Accounts on Chartbook Opening (Global Settings >> General Trade Settings >> General)
To update refer to:
[2023-09-19 17:44:02]
Thank you so much! I wasn't aware the change came with that feature :) or maybe it was there and the default setting changed only.
Either way you made my day!
[2023-10-05 15:31:38]
Is there a way to access order allocation states anyway?
For example if I want to write a study that lists accounts or number of accounts that are currently in the copy list (allocation accounts list)?
[2023-10-05 19:53:32]
No, this is not supported.
[2023-10-05 19:59:29]
copy, thank you
[2024-08-13 02:45:33]
glacialspring - Posts: 26
Would like to second a acsil getter function for order allocation enabled state. Would help to prevent a lot of copy mishaps.
