Date/Time: Sat, 23 Nov 2024 09:02:29 +0000
Spreadsheet formulas not saving
View Count: 296
[2023-06-08 13:27:46]
User358827 - Posts: 21
I am running version 2492. I have noticed that formulas in my spreadsheet are not saving. I have formulas in columns m,n, and o that have been running for quite a while with no issue, however,I added a formula to column P with a title header. This was running all day yesterday with no issues. I made sure to save the file. When I got to my desk this morning the header and formulas in column P were no longer there. The computer was not shut down and Sierra chart was not shut down. The data feed was disconnected at the end of the trading day yesterday as I always do. I have noticed this same thing happened several times before and I thought it happened because I forgot to save but yesterday I specifically saved the file to see what would happen. Can you let me know what might be causing this.
[2023-06-08 18:26:39]
What is the Number of Formula Columns set to? Make sure this is large enough to cover the columns you are having an issue with.
Refer to Formula Source Sheet Number Input description to ensure this is not related to using a different formula sheet:
Spreadsheet Study Inputs: Formula Source Sheet Number
[2023-06-09 12:25:18]
Thanks John. Columns are set to 16 but looks like I have a mismatch on the formula source sheet number that may be the problem.
Thanks for your help.
Scott
