Date/Time: Thu, 28 Nov 2024 07:58:28 +0000
[Programming Help] - ACSIL AddLineUntilFutureIntersectionEx Transparency Problem
View Count: 336
[2023-05-18 09:28:15] |
User213910 - Posts: 13 |
Hi! I have a Study which uses AddLineUntilFutureIntersectionEx. I wanted to use transparency (.TransparencyLevel = 80;) but it seems that transparency is ignored? Thanks for help |
[2023-05-18 12:13:27] |
Sierra_Chart Engineering - Posts: 17200 |
Yes transparency is not supported with those extension lines.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-05-18 12:13:38
[2023-05-18 13:02:39] |
Its in the Dokumentation: sc.AddLineUntilFutureIntersectionEx() TransparencyLevel (int): This specifies the transparency level as a percentage where 0 = 0% and 100 = 100%. 100 means that the extension line would not be visible. Date Time Of Last Edit: 2023-05-18 13:03:17
