Date/Time: Sat, 23 Nov 2024 16:44:01 +0000
Hide very top bar of program?
View Count: 1075
[2023-04-30 13:52:55]
58LesPaul - Posts: 429
I searched and saw in 2014 you stated this is not possible but watched a video and their SC program didn't show that top bar where the globe and Sierra Chart version is listed. Did you change this to where we can hide it now or did the video just cut that top bar off?
[2023-04-30 16:37:45]
Sierra_Chart Engineering - Posts: 17150
That title bar is not removable.
[2023-04-30 18:29:03]
gcUserStudies - Posts: 106
As a work around you can detach the individual chart windows. For each of those windows you can hide the Menu and Title Bar. Just right click on the chart and you should see the option. What people often do is detach and arrange all windows and put the main Sierra Chart window out of view. This is what you may have seen on the YouTube video.
[2024-08-05 20:02:58]
WyckoffSleuth - Posts: 25
old thread but on the topic ...
There is a small program called "Borderless gaming" - i sometimes use it to make Sierra full screen. Depending on what you want to achieve, how many screens youve got etc it may be better than nothing. Its not as perfect as native integration (e.g. google chrome where tabs are natively on the top bar) but may be acceptable.
Biggest downside is, that "Borderless gaming" seems to identify Sierra to have many windows (even if it is running in one window), which may make it tricky to put Sierra back to normal mode (to take Sierra out of full screen). I sometimes need to restart Sierra to return it into normal mode.
As an alternative with similar intent - I am now experimenting with 4k screen with 100% Windows scaling and increasing fonts in Sierra to make the top row as small as possible, relative to everything else. It may not be acceptable though if you need to use the same screen for other software which doesn't have settings to adjust everything inside the software (scale the needed things up), as Sierra does.
Date Time Of Last Edit: 2024-08-05 20:13:45
