Date/Time: Fri, 29 Nov 2024 08:40:10 +0000
Issue with show fills and changing trade window stats
View Count: 275
[2023-02-20 00:05:33] |
Tonkadad - Posts: 235 |
When I click "Show Fills" it changes the "Trade Window" stats. It says I am in a position with a substantial loss. When I go to "Trade Account Monitor" it shows I am flat, with the correct amount in my account. Teton SC ver 2480 |
[2023-02-20 04:32:37] |
Sierra_Chart Engineering - Posts: 17225 |
Does not make any sense to us. Do you mean this command: Trade Menu: Show Order Fills (Trade menu) Make sure you are not using the Order Fill Calculated Position: Basic Trading and the Trade Window: Main/C >> Menu >> Settings >> Use Order Fill Calculated Position (chart specific) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
