Date/Time: Fri, 29 Nov 2024 08:23:50 +0000
Is this from Sierra Chart?
View Count: 310
[2023-02-19 16:37:59] |
Solemn Philosopher - Posts: 1 |
An acquaintance of mine is working on a research paper and is trying to retrieve chart information from the files listed below. He asked me if I can open them, but I've had no luck with any programs or online file converters. I am guessing they are folder contents for a certain chart program and can only be opened there. Is this possibly a Sierra Chart file structure? Here is a snippet of the files: fig1.pic fig2.cht harve_bc.cht hg.dir seas_man.doc time-on.wk1 Any help would be greatly appreciated. Thanks! |
[2023-02-19 17:37:37] |
Sierra_Chart Engineering - Posts: 17221 |
The only file that might be associated with Sierra Chart is a file with this extension: .cht Sierra Chart uses that extension for Chartbooks. The other files are definitely not Sierra Chart files. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
