Date/Time: Fri, 29 Nov 2024 12:42:55 +0000
[User Discussion] - Order allocation
View Count: 282
[2023-02-06 07:16:11] |
Rustam - Posts: 19 |
1.Is there a way to create a group of multiple accounts and save them so you can quickly switch between groups if necessary? 2. Is it possible to set the order allocation chart across the board so that you don't have to add and remove accounts on each individual chart? If not, would it be possible to introduce this feature ? that would be a huge relief |
[2023-02-06 18:03:04] |
Both of these are Feature Requests. As with all Feature Requests, we can not say when we will get to implementation. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
