Date/Time: Fri, 29 Nov 2024 12:31:55 +0000
[User Discussion] - About Hong Kong Hang Seng Index Futures HKFE
View Count: 324
[2023-02-06 06:31:17]
User806728 - Posts: 5
Hello, I just found that Sierra Chart is very suitable for my needs. I want to buy it to use the function of Numbers bars to watch the Hang Seng Index futures and use interactive brokers to trade, but I am only an amateur trader and cannot buy too expensive packages. What is the most expensive package? How much will a basic package that meets my requirements cost per month? Can this be done with data from interactive brokers without buying the data? Thank you, looking forward to your reply
[2023-02-06 17:57:15]
John - SC Support - Posts: 36350
Since you are wanting to connect to a trading service, you will need to be on one of the Integrated packages. The monthly price for these are $36.00, $46.00 and $56.00. Refer to the information here:
Description of Service Packages and Pricing: Integrated Packages
You can use the Interactive Brokers data for your needs.
