Date/Time: Fri, 29 Nov 2024 12:57:03 +0000
data feed/charts not loading
View Count: 272
[2023-02-06 01:13:06] |
User377189 - Posts: 172 |
I logged onto the platform after a while and re-activate services.Charts are not loading. I see error message "real time data only supported by sierra chart data feed"
[2023-02-06 02:44:54] |
Sierra_Chart Engineering - Posts: 17226 |
Activate the exchanges that you need, here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
