Date/Time: Fri, 29 Nov 2024 14:47:17 +0000
Value are based on first 30 minutes
View Count: 338
[2023-02-05 22:38:21]
User658125 - Posts: 20
Basically I need a setting that draws the profile based on first 30 minutes but extends the (value area) of the profile until the end of the session.
I am trying to develop and automated trading strategy based on only trading outside of the value area created by a Vbp from the first 30 minutes of the trading session. Creating the Vbp seems to be no issue. (Multiple profiles based on start time and end time, creates profiles as I require). But, when trying to set an alert based on a color bar using the high and the low of the value area (SG3 and SG4 from the Vbp), it seems the value area stops at the end of the profile, and that's a problem. I require it to extend until the end of the trading session. In this case 16:00. I seemed to have confirmed that the value area ends by using the spreadsheet study formula to draw a line at the high and low (SG3 and SG4), and the line ends at the end of the profile.
It doesn't seem like I can find any setting that will do what I require.
How can I extend the value area to the rest of the day? It seems like this should be possible, but I am stumped and if anyone can help, it would be greatly appreciated. Or if there is a better way of doing what I am trying to achieve, I would love the input.
[2023-02-06 00:37:55]
Solved.
I thought that I would just leave this up here rather than deleting it just in case in helps someone who is dealing with the same issue.
Use the horizontal line at time study and reference the Vbp SG3 and SG4 on 2 different horizontal line studies. This will created lines to the end of the session and you then have a SGs that you can use as a reference for alerts and conditions.
