Date/Time: Fri, 29 Nov 2024 12:46:51 +0000
[User Discussion] - DRAWING TOOL IN CHART BOOKS
View Count: 272
[2023-02-05 14:22:38]
User725605 - Posts: 60
I often use the Drawing Tool to track something I mark on a higher time frame CHART to a lower time frame CHART so that it shows on the lower time frame. This is
done in ONE chart book. I often create and use different CHART BOOKS for the same market. I was wondering if there was a way to place something on a chart in ie CHART BOOK II
and use the Drawing Tool in a way to have what I have placed on the chart in Chart Book II show on a chart in a separate Chart Book that I will call CHART BOOK I.
[2023-02-06 17:31:35]
John - SC Support - Posts: 36350
You can copy Chart Drawings between Chartbooks. Refer to the information in the fifth paragraph at the following link:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
