Date/Time: Fri, 29 Nov 2024 12:32:42 +0000
SPX Data
View Count: 539
[2023-02-04 18:54:19] |
CNTrading - Posts: 13 |
Hello, I am trying to load data for SPX Cash CBOE index. I'd like to load others as well. It is not loading though. Can you help me to get this data to load? Thanks |
[2023-02-06 02:47:36] |
Sierra_Chart Engineering - Posts: 17226 |
Use one of these two symbols: SPX500 $INX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2023-02-06 04:05:07] |
I want the real, true feed of SPX. How can I get that? There are also a few other indexes within CBOE that I am wanting to look at. Do I not have access with my current data package? What else would I need? |
[2023-02-06 16:20:34] |
For now you need to use the Sierra Chart Exchange Data Feed for this and activate the CBOE index exchange: Real-Time Exchange Data Feeds Available From Sierra Chart: Cash Indexes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
