Date/Time: Fri, 29 Nov 2024 14:35:51 +0000
help with "build advanced custom studies"
View Count: 520
[2023-02-03 21:00:48]
User175554 - Posts: 10
I know nothing about C++ or ACSIl, and have just started my journey on coding software things,(literally today) so please bear with me
I had an idea for a study, and decided to use chatgpt to create something, there's several questions I have about that so if it's alright I can continue to ask after this. Basically I've gotten to the point where my final problem on creating the dll through remote build is this
he remote build did not succeed. Result:
pleasework.cpp:17:10: fatal error: SCDLL.h : No such file or directory
17 | #include "SCDLL.h "
compilation terminated.
-- End of Build -- 20:48:06
if someone could give me some tell me why this isn't working as well as advice on starting to learn that would be very beneficial, thank you in advance. I really do appreciate the response.
[2023-02-03 21:34:03]
Jagui1 - Posts: 14
Don't know if it's the right answer... but my indicators have this different #include line:
#include "sierrachart.h"
You may also look at this page for a starting reference:
Advanced Custom Study Interface and Language (ACSIL): Step-By-Step Instructions to Create an Advanced Custom Study Function
[2023-02-05 16:20:25]
user_xyz - Posts: 416
Search Frozen Tundra on youtube has many great examples to help you out, great resource
https://www.youtube.com/@FrozenTundraTrader
