Date/Time: Fri, 29 Nov 2024 14:52:24 +0000
producing horizontal line offset from another study
View Count: 286
[2023-02-03 19:32:43] |
User12089 - Posts: 361 |
on a chart, there is: Study 1 - there is a Color Bar on Alert Condition study which produces a Horizontal Line when the condition is true Study 2 - there is another study which produces a numerical value as its output Question - how to Add/Subtract the Value of Study 2, from the value at which the Horizontal Line of Study 1 is drawn and use the result to draw a second/new horizontal line, which is essentially offset from the first line (of Study 1) by the numerical value of Study 2 i tried e.g. the study Study Subgraps Add, but it didnt work |
[2023-02-03 21:57:19] |
Study Subgraphs Add or Study Subgraphs Subtract are tools that can be used and should work. Why did this not work for you?
[2023-02-04 09:25:02] |
you are missing the second part of the initial question "from the value at which the Horizontal Line of Study 1 is drawn and use the result to draw a second/new horizontal line, which is essentially offset from the first line (of Study 1) by the numerical value of Study 2" ps: simply adding, subtracting etc is easy and it works - you need to read and comprehend and then address the above question/situation as a whole so the essence of teh question is how do u INTEGRATE add/subtract with the Color Bar on Alert condition to produce a line which is offset anyway, in the meantime i found the solution which was to use the reference study/subgraph input attribute of the color bar on alert condition Date Time Of Last Edit: 2023-02-04 09:28:57
