Date/Time: Fri, 29 Nov 2024 14:55:20 +0000
DOM CHART AND HEAT MAP: NO NUMBERS SHOWING UP
View Count: 371
[2023-01-31 16:53:37]
hudaman - Posts: 5
There are no numbers showing up in my DOM chart. There is movement and data coming but I don't see any numbers. here is a screenshot. I thought this was a text color issue but I've tried changing the text color etc. and nothing seems to be working. Please let me know how I can resolve this, I must be missing something. Thanks.
imageScreenshot 1-31-23.png / V - Attached On 2023-01-31 16:52:23 UTC - Size: 37.84 KB - 106 views
[2023-01-31 17:51:44]
John - SC Support - Posts: 36350
Disable the option for Global Settings >> Graphics Settings >> Other >> Use OpenGL for Chart Graphics. We have a problem with this in recent versions that we are fixing, and we think this may be what you are seeing.
[2023-01-31 18:26:08]
hudaman - Posts: 5
Thanks John. That totally worked. Definitely would not have known that was the issue.
