Date/Time: Fri, 29 Nov 2024 14:55:05 +0000
MBO on CGQ Calendar Spreads
View Count: 315
[2023-01-31 13:00:00] |
StephenL - Posts: 98 |
Hi guys, Do support MBO data on CME, Eurex or ICE calendar spreads from CQG data? And if not, will you be in the future? Thanks, Stephen |
[2023-01-31 16:20:33] |
We do not support MBO data from any source other than our own Denali Exchange Data Feed. We do not see this changing at any point in the future.
[2023-01-31 16:23:16] |
Hi John. Do you support MBO data on CME and Eurex calendars spreads on the Denali Exchange Data Feed?
[2023-01-31 21:43:11] |
Sierra_Chart Engineering - Posts: 17228 |
Definitely not EUREX spreads since those are not supported. Market by order data is supported on some of the CME spreads. Although we have to confirm this last part.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2023-01-31 21:43:21
